When the engine is running the brake pedal goes
125,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
FREDWS
Break pedal go to floor only when engine is running. I have heard pedal that is high when engine is off. I changed master cylinder. Bled all the lines. I have no leaks in system.
Jun 29, 2017 at 3:22 AM
  • 55,770 POSTS
This sounds like you have a caliper slide that is frozen. This will cause the rotor to push the pad back into the caliper making an air gap.
Here is a guide that shows the caliper slides.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Please let us know what you find.
Cheers, Ken
Jun 30, 2017 at 5:58 AM
