Randomly the brake pedal sticks to the floor
  • 109,708 POSTS
You will be okay. The Dakota didn't have an upper and lower, but it is still basically the same. Let me know what you decide or if you have other questions.
Thursday, August 27th, 2020 AT 6:31 PM
CRAFTSMAN62
  • 18 POSTS
I got Permatex steel and metal weld and going to put a threaded stud in the bolt hole an fill it with Permatex steel an metal weld and let it sit and dry good overnight and put some in that little hole. Maybe this will buy me some time. I will see how it goes an go from there.
  • 109,708 POSTS
Sounds like a plan. Keep me in the loop. Hopefully that will buy you some time. However, I feel really confident you will be able to replace the manifold when you are ready.
CRAFTSMAN62
  • 18 POSTS
The permatex held long enough for a text short drive an that was it. It started leaking. So I found a self tapping bolt so I am good now.
CRAFTSMAN62
  • 18 POSTS
I will get back on my brakes as soon as I can. I am carrying a jug of water an antifreeze mix just in case.
  • 109,708 POSTS
Not a problem. I'll be here.
CRAFTSMAN62
  • 18 POSTS
Thanks man for all your help I appreciate it.
