The entire switch shouldn't move. Are you sure it hasn't come disconnected? Here are directions for removal and replacement. Take a look through these directions and confirm it is still properly attached. The two attached pictures correlate with the directions.
________________________
1995 Chevy Truck C 1500 Truck 2WD V8-350 5.7L VIN K TBI
Stop Lamp Switch
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Brake Light Switch Service and Repair Procedures Stop Lamp Switch
STOP LAMP SWITCH
STOPLAMP SWITCH
Remove or Disconnect
pic 1
1. Negative battery cable.
2. Retainer from brake pedal pin.
3. Switch by unsnapping from pushrod.
4. Electrical connector from switch.
Install or Connect
pic 2
1. Electrical connector into switch.
2. Switch by snapping it onto pushrod.
3. Retainer onto brake pedal pin.
4. Negative battery cable.
Images (Click to make bigger)
Friday, February 26th, 2021 AT 10:36 AM
(Merged)
