Brake lights and hazard quit working
130,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
DANOC22
  • 45 POSTS
All fuses and bulbs are good. My cab brake light works. So I ran a wire from my cab light and tide it through my trailer wires. changed out the brake relay still not working?
Dec 5, 2020 at 8:04 PM
Good morning,
I attached a wiring diagram for you to view. Check the fuse for power to the switch.
Then check voltage at the switch itself. It is under the dash on the brake pedal.
For information on stop lamp circuit diagnosis, refer to Diagrams, Diagnostic Aids.
Caution: Refer to Battery Disconnect Caution in Service Precautions.
1. Disconnect the battery negative cable.
2. Disable the SIR. Refer to Disabling the SIR System.
3. Remove the pushrod retainer from the brake pedal pin. Use snap ring pliers.
4. Unsnap the stop lamp switch from the pushrod.
5. Disconnect the electrical connector from the stop lamp switch.
Installation Procedure
1. Connect the electrical connector to the stop lamp switch.
2. Snap the stop lamp switch onto the pushrod.
3. Install a new pushrod retainer on the brake pedal pin. Use an 11 mm (7/16 inch) socket in order to push a new clip onto the pin.
4. Connect the negative battery cable.
5. Enable the SIR. Refer to Enabling the SIR System in Restraint Systems.
Dec 5, 2020 at 9:11 PM
DANOC22
  • 45 POSTS
If my cab brake light works doesn't that mean my switch is good?
Dec 6, 2020 at 4:17 AM
Correct. If it works, then the switch is good.
This means either the turn signal switch is bad or the wiring to the bulbs is an issue.
Assembly Procedure
Important: Be sure that the electrical contact of the turn signal and multifunction switch assembly (2) rests on the turn signal cancel cam assembly.
Notice: Refer to Fastener Notice in Service Precautions.
1. Install the turn signal and multifunction switch assembly (2).
2. Install the 2 pan head tapping screws (1).
Tighten the screws to 7 Nm (62 inch lbs.).
3. Slide the 2 connectors (2) of the turn signal and multifunction switch assembly into the bulk head connector (1).
4. Pop the wire harness assembly (4) into the wire harness strap (5). Install the wire harness strap (2) into the steering column support assembly (1). Install the wire harness straps (3) onto the wire harness assembly (4).
5. Install the upper and lower shrouds. Refer to Steering Column Trim Covers - Assemble Off Vehicle (Column Shift).See: Steering Column > Removal and Replacement
Dec 6, 2020 at 4:34 AM
DANOC22
  • 45 POSTS
my turn singles work fine, my hazard lights don't work?
Dec 6, 2020 at 5:02 AM
That would be from the switch itself.
Replace the switch.
Dec 6, 2020 at 4:49 PM
DANOC22
  • 45 POSTS
the brake light switch?
Dec 7, 2020 at 12:07 AM
The turn signal switch.
Dec 7, 2020 at 1:03 AM
DANOC22
  • 45 POSTS
Got my switch in replaced it it took care of my hazard light issue. Thank you for that. still no brake lights. i am not getting power to my brake relay or fuse box in the under the hood fuse box all other fuses work fine. i took out the brake light switch it did not look good, replaced it. it is getting power but still no power to my fuse box or relay. third brake light works?
Dec 17, 2020 at 3:05 AM
Okay, I attached a diagram for you to view. Check for power out of the multifunction switch with the brake pedal depressed with a voltmeter.
Dec 17, 2020 at 6:47 AM
DANOC22
  • 45 POSTS
i replaced it to fix my hazard light issue and the brake light issue was there before. i will do it.
Dec 17, 2020 at 10:38 AM
Let me know if there is power on those wires with the pedal depressed.
Dec 17, 2020 at 10:40 AM
DANOC22
  • 45 POSTS
i will thank you.
Dec 17, 2020 at 10:42 AM
You are welcome.
Always glad to help.
Dec 17, 2020 at 10:51 AM
DANOC22
  • 45 POSTS
this has a trailer brake on it under the dash. not a very good looking job. The wires in the back are hooked to nothing there taped off would this have anything to do with it ?
Dec 17, 2020 at 11:02 AM
If they go to the rear brake lights, yes. Check the colors and match them to the diagram.
Dec 17, 2020 at 11:15 AM
DANOC22
  • 45 POSTS
i have a yellow, light green, dark green, brown, blue, orange. orange and brown are hot.
Dec 17, 2020 at 11:34 AM
Yellow and dark green are the ones going to the rear lights. Check the diagram I sent you to verify.
Dec 17, 2020 at 11:43 AM
DANOC22
  • 45 POSTS
i see what your talking about. these wires go to the trailer plug so i don't know what to do with them.
Dec 17, 2020 at 12:04 PM
Do a continuity check to the rear lights from those wires to be sure that they are the wires.
Dec 17, 2020 at 8:15 PM
DANOC22
  • 45 POSTS
I tested at the new switch 2 yellow and 3 dark green to the switch 1yellow is hot with brake on or off. 1 dark green was hot with brake on or off.
Dec 20, 2020 at 4:36 AM
DANOC22
  • 45 POSTS
With brake on only the brown is hot. My cab brake light and all lights tail, turn, hazard back up all work.
Dec 20, 2020 at 5:21 AM
What about the white and orange wires going into the multifunction switch?
Dec 20, 2020 at 9:41 AM
DANOC22
  • 45 POSTS
the orange is hot brake on or off. the 2 white are not hot brake on or off. still no power to my brake relay under the hood.
Dec 21, 2020 at 2:35 AM
DANOC22
  • 45 POSTS
any other ideas?
Dec 23, 2020 at 2:03 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached an ABS brake wiring diagram below for you. You mentioned you got the lights working. Are you trying to get a trailer brake to work? Let us know and we'll figure this out. Hope this helps and thanks again for using 2CarPros. Happy Holidays.
Dec 27, 2020 at 5:56 AM
DANOC22
  • 45 POSTS
my truck brakes have been my problem and still are my problem.
Dec 27, 2020 at 3:56 PM
DANOC22
  • 45 POSTS
what are these drawings for? I have a 2000 k3500 454 4x4 automatic stander cab .This seems different.
Dec 27, 2020 at 4:16 PM
Sorry for the delay, where is the connector from in your picture? Where does that white wire go?
Dec 27, 2020 at 5:30 PM
DANOC22
  • 45 POSTS
The white wire is hanging from the original wiring harness. no sign of it connected to anywhere.
Dec 28, 2020 at 1:58 AM
If you look at the original wire diagram I sent you in the beginning, the white wire is from the brake light switch. It feeds the turn signal switch as well as the brake relay.
Test that for voltage with the pedal depressed.
Dec 28, 2020 at 5:01 AM
DANOC22
  • 45 POSTS
should it be hot with brake depressed?
Dec 28, 2020 at 5:51 AM
Yes, it should. Look at the diagram I posted in the beginning and you will see that wire feeds off to several places.
Dec 28, 2020 at 6:01 AM
DANOC22
  • 45 POSTS
I tested the white wire it's hot when depressed.
Dec 28, 2020 at 6:03 AM
DANOC22
  • 45 POSTS
What does it connect to?
Dec 28, 2020 at 6:06 AM
DANOC22
  • 45 POSTS
i am lame on these drawings. i know it's right in my face. but i'm struggling here.
Dec 28, 2020 at 6:15 AM
It goes to A1 in the wire diagram I sent you for the multifunction switch.
It also goes to the underhood fuse block for power to the relay.
Dec 28, 2020 at 6:24 AM
DANOC22
  • 45 POSTS
i see where it goes to the stop light switch and to the relay, i don't see what it connect to at the rear of the truck.
Dec 28, 2020 at 6:58 AM
DANOC22
  • 45 POSTS
do i need to open the harness did it pull out of there?
Dec 28, 2020 at 7:00 AM
It does not connect to the rear of the truck. If you see where it goes to the relay, look down further and it connects to the multifunction switch at terminal A1.
Dec 28, 2020 at 7:05 AM
DANOC22
  • 45 POSTS
so it just hangs at the rear of the truck?
Dec 28, 2020 at 7:10 AM
