brake pedal was very stiff
1995 GMC SIERRA
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JEREMY0507
  • 27 POSTS
So my brake pedal was very stiff an my truck was barely stopping so I changed the brake booster.The issue has not changed. It is still hard and my engine idles higher when I push brake pedal which it did before also.Think I got a faulty booster or maybe another issue?
Jun 5, 2018 at 7:08 AM
  • 110,240 POSTS
Hi and thanks for using 2CarPros.com. If it is doing the same thing, it does not sound like a booster problem. For the booster to operate properly, it needs eighteen inches of vacuum from the engine. Remove the vacuum hose to the booster and check if you are getting that. If you are not suspect there is a plug in the hose, a cracked hose, or another vacuum leak causing engine vacuum to drop.
Here are directions for checking engine vacuum and how to identify a leak:
Try this first and let me know what you find.
Apr 14, 2021 at 6:47 AM
JEREMY0507
  • 27 POSTS
Will a vacuum leak cause the brake pedal to get very hard an not let the vehicle stop?
  • 110,240 POSTS
Hi again. The reason the pedal is normally easy to press is because of engine vacuum in the brake booster. If there is a leak, you may not get the assist. Hence, it is hard to press.
JEREMY0507
  • 27 POSTS
I checked the vacuum hose going to the booster an it is still good. There is lots of vacuum. Would a bad ABS module cause this?
  • 110,240 POSTS
Hi, honestly the module would not cause this. Have you checked intake vacuum with a gauge to determine if it is adequate?
  • 110,240 POSTS
After thought. Is there a white one way valve on the booster where the vacuum hose connects? If so, remove it and see if it is blocking vacuum.
