front brakes started to hang up
1992 GMC SIERRA
375,000 MILES • 6 CYL • 2WD • MANUAL
NAGOWA
My front brakes started to hang up and did not retract so I replaced the rotors,calipers,bearings,and master cylinder.But they are still hanging up.Would it be the booster?
Mar 21, 2010 at 12:54 PM
  • 110,244 POSTS
Chances are the rubber brake hoses that go to the caliper are bad. THey actually deteriate inside and will allow brake fluid to pass in one direction and not the other. Check that. Also, the booster wouldn't cause this type of problem.
Let me know if this helps.
May 8, 2021 at 5:56 AM
