Boggs down when gaining speed
2009 DODGE CHARGER
215,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
CHASELAKEY0
If you drive the car slow with barely any gas but reasonable acceleration it won't bog down, but give it 25 percent on the gas or more the car shakes and shutters. if you floor it sometimes it will just bog out unless you are in the power band range 30 and 60 area you can floor it no problem just gaining speed. but I recently put in on the dyno and you can feel the transmission hard shift downshifting from 5th to 4th only have no misfires new computer dyno tuned went through 3 camshaft sensors to make sure. oil pressure sensor replaced wiring checked out fuel system checked. only thing I haven't checked is the transmission. I just wanted to know if my car will bog out not slip at all because of the transmission and you can't take off the line trying to race anybody.
Jun 10, 2021 at 12:45 PM
  • 110,241 POSTS
If the transmission is slipping, the engine RPMs will increase without the vehicle speeding up at an equal rate. A bog normally indicates a lowering of the RPMs.
Have you checked the transmission fluid to see if it is full and clean? Also, are there any diagnostic trouble codes?
Jun 11, 2021 at 2:57 PM
CHASELAKEY0
No codes and doesn't slip it only bogs with increase of speed.
Jun 11, 2021 at 11:57 PM
CHASELAKEY0
Maybe a torque converter?
  • 110,241 POSTS
I wouldn't think the converter would cause an engine bog. The heavier you are on the throttle requires more fuel and air to the engine. If it bogs when you request more power, the first thing for me is the fuel pump is weak or there is an air restriction to the throttle body.
Have you confirmed fuel pressure? Also, do you have a live data scan tool?
If you have a live data scan tool, let me know what the short-term fuel trims are at operating temperature. Also, if you haven't, you should check the fuel pressure. There could even be an issue with a filter restricting fuel.
Here is a link that explains in general how to test fuel pressure:
Let me know if this has already been done and the results.
Jun 12, 2021 at 1:46 PM
CHASELAKEY0
I have done a fuel pressure test it sits at 52 53 PSI and I don't have a scan tool they have checked my air to fuel ratio already from what I was told when I put it on a dyno to have it tuned.
Jun 14, 2021 at 3:15 AM
  • 110,241 POSTS
Fuel pressure is low. Non SRT-4 fuel pressure specification is 407 KPa +/- 34 KPa (59 psi +/- 5 psi). SRT-4 fuel pressure specification is 552 KPa +/- 34 KPa (80 psi +/- 5 psi).
If there isn't enough pressure, it can cause a bog.
Jun 14, 2021 at 1:22 PM
