2005 BMW X5
DUONG
  • 2005 BMW X5
2005 BMW X5
how to open the pad side on the driver door to see the glass window motor inside
Tuesday, May 4th, 2010 AT 6:39 AM
DOCHAGERTY
  • 9,603 POSTS
The door panel has screws behind the long wood trim piece, the "SRS" emblem and down low above the storage pocket, they are Torx screws. Remove them and then insert a plastic wedge between the door panel and the door itself and pop the panel loose, it takes a bit of force. Then pull up and release the panel, remove the cables and carefully take loose the vapor barrier, I use a razor blade.
Tuesday, May 4th, 2010 AT 10:04 AM
