2003 BMW X5 Rear Passenger Window
2003 BMW X5
71,243 MILES • 6 CYL • AWD • AUTOMATIC
MELANIE100
My Rear Passenger window will not go up. I tried replacing T-Bar and also Motor on door. Neither worked. Any other ideas to repair. BMW wants $600 to diagnose.
Thanks
Aug 29, 2008 at 10:25 AM
DOCHAGERTY
  • 9,606 POSTS
Is the motor not working? It may be the drivers door switch module as it is the master controller for the window motors. It could also be the conductor or connector.
Aug 29, 2008 at 3:43 PM
DOCHAGERTY
  • 9,606 POSTS
Is the motor not working? It may be the drivers door switch module as it is the master controller for the window motors. It could also be the wiring(conductor) or one of the connectors or a loose ground.
Aug 29, 2008 at 3:45 PM
