ABS light on
MECHANICRG
ABS light on after changing brakes. How do I reset the system to turn the ABS light off? Sensors are connected and no fault codes! Light has been on for two months since replacing brakes.
Oct 17, 2007 at 4:25 AM
  • 55,721 POSTS
It sounds like the new rotors do not have the ABS wheel reluctor on them. Did you match the rotors up?
Here is a guide to help you test the BAS wheel speed sensors to confirm the problem.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Cheers, Ken
Aug 3, 2017 at 9:21 AM
MAYORG
high mileage, oil serviced recently, replaced spark plugs..
Aug 3, 2017 at 9:21 AM (Merged)
DAN_K
  • 213 POSTS
You will need to scan the vehicle to determine the Diagnostic Trouble Code (DTC) for the ABS system.
Begin your diagnosis there.
