whistling noise at low speed and middle of the day usually
2004 BMW X5
45,000 MILES • 3.0L • AUTOMATIC
ASHLEY MINNICK-RUSSELL
My car has had many repairs. Latest issue is a whistling sound that is getting louder. The whistling can happen straight away in the morning even idling and then up to about 60 km per hour then it goes away. Mechanic suggested replacing pulleys and perhaps alternator. Think he is on the right track? I am just not sure what the speed and time of day contribute to the issue?
Nov 16, 2016 at 11:53 PM
JIS001
  • 3,412 POSTS
When you start it up and it whistles, remove the oil cap or pull up on oil dipstick if it has one. If the whistle goes away and there is a lot of vacuum from the crankcase then the oil separator has failed. The intake manifold will need to be removed to access the part and I would recommend you replace all the PCV hoses as well since they will break when removing the intake. Usually with an internal vacuum like that the Check Engine light or Service Engine Soon light should come on with fuel trim faults. I have also seen it where it is so bad that smoke will start to come out the tail pipe from it sucking oil. Let us know how that first test turns out.
Nov 17, 2016 at 2:28 AM
I tried removing the dipstick while the engine was running and the whistling was present. No luck. Whistling continued.
Nov 17, 2016 at 3:16 AM
JIS001
  • 3,412 POSTS
Okay then, if the noise is more of a chirping sound then spray some WD40 on the belts. If noise goes away replace the belts. If it still makes noise, have your mechanic remove the belt and run the engine again. If the noise goes away then spin each pulley one at a time and check them for play. If the noise is still present when the belts are removed then your mechanic is going to need to try to figure out what is going on. Those are simple tests you can do before throwing parts and money and still end up having the same noise? Let us know how it goes and what you end up finding.
Nov 17, 2016 at 3:22 AM
Car is back to new after replacing belts and pulleys. Thank goodness. Thanks for your input!
Dec 12, 2016 at 4:18 AM
  • 55,432 POSTS
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Dec 12, 2016 at 4:51 AM
