2002 BMW X5 bumping noise on turns
2002 BMW X5
70,000 MILES • V8 • 2WD • AUTOMATIC
HICKS
on left turns ( not always replicated, just 'certain' angles + incline, a bump, bump, bump seems to be coming from left front wheel area- nsounds like something rubbing but not scraping-
tires don't indicate extra wear in inside or out edges. when looking inside wheel well notice area of grease has been rubbed off on vertical rod/post that attaches to wheel axle.-??? Thanks for the help-
lady driver
all else seems to be ok.
Jan 9, 2009 at 11:13 PM
DOCHAGERTY
  • 9,606 POSTS
The issue is most likely the left side half shaft. That's the axle from the wheel to the front differential. It has a torn boot and has leaked the grease out. The outside CV joint can be purchased separately now as they are a high failure item and the installation requires special tools. Do you have a mechanic for your BMW yet?
Jan 10, 2009 at 2:13 AM
