2000 BMW 740i sport. car won't start in cold weather!?!?
103,855 MILES • V8 • 2WD • AUTOMATIC
RGG310
i have a 2000 bmw 740i. when the weather is hot or warm it starts up good but when the weather changes to cold i turn the key to position 2 and everything seems fine,dash lights up but i also hear a click coming from the glove box and when i turn it to turn the car on nothing happens. when the weather gets hot the only thing i notice is when i turn the key to any position there is a click on the left side by where you turn the headlights on and thats the sign i know it will turn on. please help.
Dec 18, 2008 at 12:16 PM
DOCHAGERTY
  • 9,606 POSTS
When did this start? What has been done to correct this issue? Is the battery old?
Dec 19, 2008 at 3:56 AM
RGG310
hello and thanks for the reply,well it started when i moved from from california to utah in cali weather is hot and humid,when i moved to utah it was june it was fine but now the weather is cold its been 3 days and can't get it to turn on i bought a new battery and nothing. i turn the key to the on position averything lights up then i turn the key to turn on the car and nothing its like it doesn't have a battery but everything else works. last time when i took it to autozone because my check engine light came they put that reader and gave them a code: p0170 and p1340.
Dec 19, 2008 at 4:14 AM
DOCHAGERTY
  • 9,606 POSTS
It is possible you have an issue that will require a local BMW tech to take a look at. There is a need for fuel, spark, and compression to make a gasoline internal combustion engine run. If you are not getting these three things then you and I can work together to try and fix it.
Dec 19, 2008 at 7:01 AM
RGG310
hello again,well i tried to start and wen't under the car to see if it was the starter tried manually with the key on position 2 but it would not start again,and if it was the fuel pump the car would shut off or sputter but as soon it turns on it runs normal even if i shut it off it turns on again. i put the jumper cables and hook it up to my truck and left it charging for about 30 minutes and then it turned on. now i know if i take it to a bmw dealer they might charge alot of $$ but dont know where else to take it. where i live there arent alot of options "ogden utah". what would you recomend?
Dec 31, 2008 at 7:40 AM
