1995 BMW 740i Rough After Engine Wash
GEEK
155,000 miles
1995 BMW 740i
After Degreesing the engine with engine cleaner (foam) and a garden hose, the engine seems to be running very rough and a loss of power and pick up. I thought I had gotten something wet electrical wise, so I blew out all the contacts I could find with air, and this did not not help. Now the check engine light comes on and stays on. I am not sure how/where to check for codes.
Aug 8, 2007 at 1:21 PM
DOCHAGERTY
  • 9,606 POSTS
the 20 pin diagnostic connector is in the engine compartment on the right side near the strut tower.
it is round and black and about 3.5" in diameter.
as far as how to check for faults you could find a local shop that has a GT-1 or it's equivalent and have them read out the faults.
Aug 10, 2007 at 6:01 PM
CORVETTE_49
[quote:1d75f84557="geek"]155,000 miles
to check for c1995 BMW 740i
After Degreesing the engine with engine cleaner (foam) and a garden hose, the engine seems to be running very rough and a loss of power and pick up. I thought I had gotten something wet electrical wise, so I blew out all the contacts I could find with air, and this did not not help. Now the check engine light comes on and stays on. I am not sure how/where odes.[/quote:1d75f84557]I done the same thing about two weeks ago. pull your plugs and dry everything out . put in new plugs. problem solved
Aug 21, 2007 at 9:16 AM
Suggested Repair
Dry the engine and ignition components thoroughly, remove the spark plugs and dry them or install new plugs, and have fault codes read at the round 20-pin diagnostic connector near the right strut tower using a GT-1 or equivalent scan tool.
Conversation Summary
A 1995 BMW 740i began running rough with reduced power after the engine was degreased with foam cleaner and rinsed with a garden hose. Blowing out electrical contacts did not help, and the check engine light stayed on. An expert identified the round 20-pin diagnostic connector near the right strut tower and recommended a shop with a GT-1 or equivalent read the faults. Another owner reported the same issue was resolved by pulling the plugs, drying everything, and installing new plugs.
