2001 BMW 740i Rough Acceleration
BODEJEGEDE
  • 12 POSTS
2001 bmw 740i v8 engine refuses to pick up speed smoothly from take off as it surges and acceleration is rough from scracth but vehicles movement is good at top speed.i also noticed the presence of engine oil on one of the plug outlet.i suspected a throttle and throttle body failure since the battery power output is not at the pick for i have to jump start battery in the morning during first start.what do i check assist please.
Sep 11, 2007 at 3:41 AM
DOCHAGERTY
  • 9,606 POSTS
If you have leaky valve cover gaskets and the spark plug wells are filling with oil, address that issue and replace the spark plugs and repost if that does not help.
Sep 11, 2007 at 3:10 PM
Suggested Repair
If the valve cover gaskets are leaking and oil is filling the spark plug wells, repair the gaskets and replace the spark plugs. Recheck the rough acceleration if it continues.
Conversation Summary
The owner of a 2001 BMW 740i reports surging and rough acceleration from a stop, though the car runs well at higher speed. Oil was found on one spark plug outlet, and the battery needs a jump for the first start. The expert advises addressing leaky valve cover gaskets if the plug wells are filling with oil and replacing the spark plugs, then following up if the problem remains.
