1994 BMW 740 o2 sensor
1994 BMW 740
KIOWA33
Engine Mechanical problem
1994 BMW 740 V8 Two Wheel Drive Automatic 98K miles
My car stopped running in my work's parking lot. I know it's the o2 sensor. i need instructions on where it is located and is it possible to replace the sensor while it is jacked up in a parking lot. or is it to difficult to change due to the placement of the o2 sensor?
Sep 13, 2010 at 5:52 PM
DOCHAGERTY
  • 9,606 POSTS
It isn't the oxygen sensor. http://www.realoem.com/bmw/showparts.do?model=GD43&mospid=47362&btnr=18_0222&hg=18&fg=05
O2 sensors have no effect on the cars ability to start and run. If the heater circuit is compromised then there will be a blown fuse.
Sep 14, 2010 at 1:17 AM
DR LOOT
  • 2,311 POSTS
Dr. Hagerty is correct, it is most likely the crank sensor or you have a bad fuel pump check all fuses and relays.
Sep 27, 2010 at 4:42 PM
