1994 BMW 740 Coolant smell
134,000 MILES • V8 • 2WD • AUTOMATIC
ESLEZ9MZTX
I have been having a coolant smell around my block for a while. The smell is particularly strong right at the center of the block, near the throttle body. Ideas?
Mar 2, 2008 at 5:48 AM
DOCHAGERTY
  • 9,606 POSTS
The valley pan will require replacement and you should renew the PCV plate while you are in there along with the intake manifold gaskets and the rear coolant manifold gaskets. This is about a 6 hour job for me, give yourself twice that amount if you wish to take it on yourself.
Mar 3, 2008 at 6:44 AM
