2002 BMW 530i Dash Digits Missing
JOHN ASKEW
2002 530i BMW, 76,000 miles, auto tranny, engine 3.5L, this is the E39 model. The LED (I assume) numbers on my dash do not fully illuminate. Parts of the numbers are missing. For instance at times the temperature outside indicated on the dash will be fully illiminated but then while driving parts will go away. About a year ago I had to replace the battery. When the new battery was put in, no problem, but over about 4 months the problem returned. All else works well.
This happens sometimes on the radio face as well.
Thanks.
Nov 21, 2007 at 7:29 AM
DOCHAGERTY
  • 9,606 POSTS
The displays are back lit liquid crystal and are not repairable. Replacement is the only cure.
Nov 21, 2007 at 7:55 AM
SAFEDRIVER213
  • 10 POSTS
you have the same problem i have! the above poster suggested the same thing. my car is still under extended warranty. i wonder if this would be covered by it?
Oct 23, 2008 at 11:33 AM
Suggested Repair
Replace the instrument cluster display. The backlit liquid crystal displays are not repairable, and replacement is the only fix. The same applies if the radio face display fails the same way.
Conversation Summary
A 2002 BMW 530i owner reports instrument panel digits that do not fully illuminate, with segments disappearing while driving; the radio face sometimes does the same. The issue returned months after a battery replacement, while everything else works. An expert says the displays are backlit liquid crystal units that cannot be repaired and must be replaced. Another owner reports the same problem and asks whether extended warranty coverage might apply.
