2000 BMW 328i Rough Idle Misfire
TLOCK0000
My 2000 BMW 328i check engine light comes on for a week or so at a time and when it is on the car idles rough and runs rough. It gets better when the car warms up. I had auto zone do a check engine scan and it said (multi cylinder mis-fire). I was told i needed a tuneup but when the light goes out the car runs perfect.
Vin JR59777
Nov 18, 2007 at 12:01 PM
DOCHAGERTY
  • 9,606 POSTS
Thanks for getting back to me with the vin. The spark plugs may require replacement and it is recommended at 100,000 miles. If the fault diagnosis is not specific(if there is no cylinder identification for the misfire) I would try replacement of the spark plugs first. The NGK spark plug # is BKR6EQUP and the BOSCH spark plug # is FGR7DQP. Please do not attempt to install other types of spark plug as they may cause faults, I have seen platinum or other "premium" plugs sold by parts people trying to do what they believe is the right thing, only it isn't, trust me on this. repost to me if you need further assistance, good luck and have a good day
Nov 18, 2007 at 4:19 PM
TLOCK0000
Thanks I will change spark plugs to what you recommended. I will reply to let you know if this solves the problem. and to make donation
Nov 19, 2007 at 9:07 AM
Suggested Repair
Replace the spark plugs first with NGK BKR6EQUP or Bosch FGR7DQP only. Do not use other platinum or premium plugs, which can cause faults. Spark plugs are recommended around 100,000 miles when the misfire code does not identify a specific cylinder.
Conversation Summary
The owner of a 2000 BMW 328i reported an intermittent check engine light with rough idle and rough running that improved after warmup. A scan showed a multi-cylinder misfire. The expert recommended replacing the spark plugs first with NGK BKR6EQUP or Bosch FGR7DQP only, noting that other plug types can cause faults. The owner planned to install those plugs and report the result.
