1998 BMW 528i Stalls While Driving
IZO1975
I bought the car last year on 101 000 km .Now is 112 000.The engine is 6 cylinder 2.8i ,M52 .It hapens two times.While i drive the car and suddenly the battery and oil pressure lights goes on and the car stops.I am lucky no accident happend because the steering ring became hard and brakes also. After remove the ignition key and wait 15 seconds i start the engine and everything was fine.Also i figure out after bying the car that fuell gauge arrow never goes to max after i full the tank.Also while drive in traffic the arrow goes left and on the highway back to the righ.After i drive 450 km it show me that there is no more km left to drive.But still there is fuel because only 55 liter need to full the tank.Means that there is around 15-20 liter inside.What can be the problem?
Jun 30, 2007 at 1:31 AM
DOCHAGERTY
  • 9,606 POSTS
the tank senders are bad, replace them.
the stalling issue could be the ignition switch
repost if more help is needed
Oct 31, 2007 at 7:32 AM
Suggested Repair
Replace the faulty fuel tank sender units. For the stalling, check and likely replace the ignition switch.
Conversation Summary
A 1998 BMW 528i with the M52 engine stalled twice while driving, with battery and oil pressure lights coming on and power steering and brakes becoming hard. It restarted normally after the key was removed and the driver waited about 15 seconds. The fuel gauge also never reaches full, moves while driving, and shows empty while fuel remains. The expert said the tank senders are bad and should be replaced, and that the stalling could be caused by the ignition switch.
