1999 BMW 528
DUBSTER
  • 1999 BMW 528
  • 6 CYL
  • 4WD
  • 129,456 MILES
Hi, the above vehicle when first started in mornings, the engine hunts when idling and also hesitates when pulling away. The car has been scanned and no fault was shown related to engine electrical system and there are no air leaks on the inlet manifold.
Any idea what the problem can be?
Wednesday, January 28th, 2009 AT 4:18 PM
DOCHAGERTY
  • 9,601 POSTS
I recommend trying some injector cleaner.
Wednesday, January 28th, 2009 AT 5:52 PM
DUBSTER
  • 31 POSTS
Thank you for your promt reply. Is the injector cleaner in a liquid form which is added to the car tank alongside the petrol?
Friday, January 30th, 2009 AT 4:32 PM
DOCHAGERTY
  • 9,601 POSTS
That would be one method, yes.
Friday, January 30th, 2009 AT 6:14 PM
DUBSTER
  • 31 POSTS
Thanks. I will try this asap. U said this is one method. What others are there that I can try.
Saturday, January 31st, 2009 AT 3:55 PM
DOCHAGERTY
  • 9,601 POSTS
Try the in tank stuff first and be patient, it takes time to work. There is also a more intensive professional type that I have used, it requires the purchase of $$ tools and is quite effective. Lets go with the less expensive method first.
Sunday, February 1st, 2009 AT 12:20 PM
DUBSTER
  • 31 POSTS
Thanks for your reply. I have put a quater of the injection cleaner in with a quarter petrol. I will keep doing this until the bottle finishes and see what happens.
Sunday, February 1st, 2009 AT 3:19 PM
DOCHAGERTY
  • 9,601 POSTS
Let's see if it helps.
Sunday, February 1st, 2009 AT 6:40 PM
DUBSTER
  • 31 POSTS
Hi, regards to the fuel injector, the liquid has now been used up. Car seems to improved a bit but still hesitates and hunts at times, even in warm weather. Is there anything else I can try?
Also the speedometer and the computerized mileage in car is now not working. My abs still nedds to be replaced. Is the abs causing this?
Sunday, February 22nd, 2009 AT 2:49 PM
DOCHAGERTY
  • 9,601 POSTS
Try a different fuel from a Chevron if you have one nearby. As to the speedo being inop, it is related to the ABS issue, fix the DSC and the speedometer will start working again. DSC is dynamic stability control and is tied to the ABS
Sunday, February 22nd, 2009 AT 7:30 PM
DUBSTER
  • 31 POSTS
Thank you very much for your prompt reply. You are a star!
Monday, February 23rd, 2009 AT 7:56 AM
DOCHAGERTY
  • 9,601 POSTS
Let me give you the web sites admin address so you can tell them how wonderful I am, LOL.
Monday, February 23rd, 2009 AT 12:20 PM
DUBSTER
  • 31 POSTS
Hi again, I forgot to ask what you mean by a chevron? Is this a brand of fuel injector?
Monday, February 23rd, 2009 AT 3:31 PM
DOCHAGERTY
  • 9,601 POSTS
Its a petroleum products distributor.
Monday, February 23rd, 2009 AT 5:53 PM
DUBSTER
  • 31 POSTS
Hi again,
sorry for my ignorance, but I still do not understand what u mean by chevron being a petroleum products distributor?
Is it a brand of fuel injecotr or name of petrol.
Tuesday, February 24th, 2009 AT 8:44 AM
DOCHAGERTY
  • 9,601 POSTS
Chevron is on the internet, type it in.
Tuesday, February 24th, 2009 AT 10:20 AM
DUBSTER
  • 31 POSTS
Hi, one of my keys to the car stopped working. I changed the battery in it and now it can only start the car, I cannot lock/unlock car with key.
I was told that key needs to be programmed, when I do this it swipes out my spare key.
Any idea on how to get both keys working.
Monday, March 9th, 2009 AT 5:35 PM
DOCHAGERTY
  • 9,601 POSTS
You will need to reinitialize both keys. Get in the car, shut the door, put the key in the and turn it on then off then take it out and hold the unlock button and press the lock button 3 times and then let the unlock button go, then the central locking system will lock and unlock all the doors and then you repeat the same process with the second key. Do you understand?
Tuesday, March 10th, 2009 AT 7:18 AM
DUBSTER
  • 31 POSTS
Thank you as usual for your prompt reply. I will try this asap. Only one question, do you turn the car on fully when you put key in and out.
Thursday, March 12th, 2009 AT 4:47 PM
DUBSTER
  • 31 POSTS
Hi, I have tried several times with both keys as u described. They both do work. However, after the second key is done, the first key seems to be swiped out again. Any other way around this?
Friday, March 13th, 2009 AT 8:31 AM
DOCHAGERTY
  • 9,601 POSTS
There may be a problem with the sequencing. Try disconnecting the battery over night and reinitializing both keys again.
Friday, March 13th, 2009 AT 10:51 AM
