2000 BMW 528 02 sensor heater code
98,548 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMSFAMILY518
The miles 0n my 2000 528i is 98548. My engine recently hydro locked. I bought a engine with 48541 documented miles and had one of my mechanics at the Pontiac Buick GMC store I run do the instalation. the climate in kansas currently is rather cold and since i have had it back initally it has had a rough idel when cold and sometimes dies when idling. today I had a check engine illuminate. I had it scanned and it said 02 sensor heater circut malfunction c bank #2 sensor #2
Mar 4, 2009 at 6:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to check your oxygen sensors. If OK, check wiring to sensors. If this is OK too, need to flow test the catalytic converter.
Thanks for using 2CarPros.com!
Mar 4, 2009 at 7:45 AM
DOCHAGERTY
  • 9,606 POSTS
I agree, the fault could be for pinched wires or a bad sensor. Good call bluelightnin6, good on ya.
Mar 4, 2009 at 10:34 AM
