1997 BMW 528 no start
HAWK27
  • 1997 BMW 528
  • 6 CYL
  • 135,000 MILES
I replaced my cam position sensor, crankshaft position sensor, battery, and spark plugs. Prior to cam pos sensor, The car would start and run with a lot of bucking when accelerating. It would not start after replacing cam sensor so I began to replace other things listed above. When I turn the key, it will crank but not turn over. What could have gone wrong? I appreciate your service, thanks
Saturday, October 9th, 2010 AT 9:55 PM
DOCHAGERTY
  • 9,601 POSTS
Why were the sensors replaced in the first place?
Monday, October 11th, 2010 AT 10:35 PM
HAWK27
I mistakenly replaced the cam sensor first, then the cps. I had a lot of jerking and dogging when I would accelerate.
After a lot of investigating, I found two severed wires under the intake manifold, they had deteriorated over time and finally disabled the start-up. Problem has been solved.
Tuesday, October 12th, 2010 AT 12:04 AM
DOCHAGERTY
  • 9,601 POSTS
Thanks for the update.
Tuesday, October 12th, 2010 AT 8:35 AM
