1994 BMW 525i Fuel Pump
OLIVER BEALE
  • 1994 BMW 525I
  • 6 CYL
  • MANUAL
  • 13,000 MILES
I had my fuel pump bench checked and it's OK. I replaced a bad fuel pump relay. Fuel pump fuse doesn't get power. I was told it must be the DME. I have two questions; Can I get a used DME and program it to my car? And if not can I hard wire my fuel pump with a toggle switch in the cockpit to turn the fuel pump on when I'm using the car. If so, how exactly do I wire it?
P.S. I did run a jumper wire from the Green/Violet wire at the fuel pump to the 6 or 9 slot which is putting out 12 volts at the relay female recpt, and got the fuel pump to come on but the motor still won't start.
Wednesday, October 27th, 2010 AT 9:33 AM
Check if you're getting spark and the injectors are pulsing
Wednesday, October 27th, 2010 AT 11:02 AM
OLIVER BEALE
What about this DME module? Can I use one from another car and program it to my car. And if I wire the fuel pump like I said should it work?
I can see the spark plugs but how do I get to them. I took the 4 hold downs on the fuel rail but it won't come up, is it as simple as removing the two fuel lines? And how do I check for injector pulse?
Thanks for your help in advance.
Wednesday, October 27th, 2010 AT 11:31 AM
