1992 BMW 525i No voltage to fuel pump fuse
288,000 MILES • 6 CYL • 2WD • MANUAL
RONNIEJ1953
My 1992 BMW 525i will turn over, but will not start or run. Sprayed starter fluid in throttle-body and car tried to start. Upon further investigation found that no fuel getting to fuel rail, also found no voltage getting to electric fuel pump. I haven't checked the fuel pump relay because I don't know where it is located. Any help you can give will be greatly appreciated.
Mar 9, 2009 at 8:19 AM
  • 75,988 POSTS
Fuel pump check fuse no.23 and The fuel pump relay is behind right shock tower
Mar 9, 2009 at 9:17 AM
DOCHAGERTY
  • 9,606 POSTS
The fuel pump relay is inside the E-box.
Mar 10, 2009 at 12:31 AM
