1994 BMW 525i fuel pump
1994 BMW 525I
12,800 MILES • V8 • 2WD • MANUAL
OLIVER BEALE
fuel pump doesn't come on...like to know where the DME unit is on the car and also if I were bring a wire lead with switch into the cockpit...where is the best place to pick up the fuel pump hot wire?
I had the fuel pump bench checked and it works and the relay was replaced and gets voltage to the plug.
The fuel pump fuse doesn't get voltage.
I can't afford replacing the DME Module right now
Oct 21, 2010 at 8:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The DME unit is located on the right rear corner of the engine compartment, next to the fuel pump relay. Fuel pump wiring will be green/violet and a brown wire. The brown wire is located below the right rear seat.
Oct 21, 2010 at 8:07 AM
DOCHAGERTY
  • 9,606 POSTS
Also send the last 7 of the VIN so we can ID the car correctly.
Oct 21, 2010 at 8:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
sorry forgot to mention, the green/violet will be hot wire and brown wire is ground.
Oct 21, 2010 at 10:00 AM
