1987 BMW 525 High Fuel Use
SELEBALO
I have a BMW 525e 1987 model that has travelled about 310 000km. It is a 5 series with 6 cylinders. The amount of petrol it now consumes is twice its specification. It is 15 litres in 100 km while it should be 7.5litres per 100km. It's spark plugs have just been replaced and the caborn oxide it emits is still normal. Can you please tell me what the problem could be.
Jun 5, 2007 at 12:10 AM
  • 55,770 POSTS
First of all you should have the car scanned to help pin point the problem, it will probably tell you that your Mass Air Flow Sensor is out of range. A couple of things can cause this. 1. You have a tear in your air intake boot, inspect to replace as needed 2. the MAF sensor itself is operating out of range and needs to be replaced. Please check it out and get back to us, thank you for visiting 2Carpros.com
Jun 5, 2007 at 9:41 AM
Suggested Repair
Scan the car, which may show the mass airflow sensor out of range. Inspect the air intake boot for tears and replace it if needed, or replace the MAF sensor if it is operating out of range.
Conversation Summary
The owner of a 1987 BMW 525e with about 310,000 km reports fuel use of 15 L/100 km, double the specified 7.5 L/100 km, despite new spark plugs and normal carbon monoxide emissions. The expert recommends a scan and checking for a torn air intake boot or a faulty mass airflow sensor.
