2003 BMW 525i Cold No-Crank
GKOPEREK
I own a 525I (2003) with 67K. Recently, it will not start on the first attempt, nor does it turn over. Sort of like when an alternator goes out, nothing happens. I am afraid it is the starter? However, it will generally start right up on the 2nd attempt and drive fine.
Aug 25, 2007 at 6:24 PM
  • 75,988 POSTS
[quote:c521cf2f50="gkoperek"]I own a 525I (2003) with 67K. Recently, it will not start on the first attempt, nor does it turn over. Sort of like when an alternator goes out, nothing happens. I am afraid it is the starter? However, it will generally start right up on the 2nd attempt and drive fine.[/quote:c521cf2f50]
Try a loose battery connections and also at the starter. Maybe the ignition switch contacts with the start circuit and power input to the switch are not in good terms- when you turn key-could be on its way out or the relay/NSS.
Aug 25, 2007 at 7:27 PM
Suggested Repair
Check for loose battery connections and connections at the starter. Also inspect the ignition switch start-circuit contacts and power input, plus the starter relay or neutral safety switch (NSS).
Conversation Summary
The owner of a 2003 BMW 525i with 67,000 miles says it does not crank or start on the first cold attempt, then usually starts on the second try and drives fine. The expert recommends checking loose battery and starter connections, the ignition switch start circuit and power input, and the starter relay or neutral safety switch.
