1994 BMW 525i Running Hot
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
put original back in 88c . radiator & bottom hose got warm so let it idle 1/2 hour. needle at 1/2 way mark so took car for a ride on highway at 70mph needle still 1/2 way mark & that is with heater on . so turned heater off and needle still at 1/2 way mark when pulled in driveway opened bleeder vale & no bubbles &even top of radiator was warn bottom hose was a litte hotter. so i think it's okay now. thanks
. is there any other way to check theese tensioners to see if there okay. if so can you tell me. thank you pepperone
hi dr. put new radiator in & still goes to 3/4 mark on gauge bottom hose cold & after driving car for 1/2 hour & top hose is hot but very hard to sqeese seems like water not going back to engine i belive it could be thermostat not opening. would there be heat in car if thermostst does not open. so i sent thermostst to BEHR in germany to test it for me. every thing is new .don't know what else to do.how do you test a thermostat.maybe i am not testing them the right way. i use a candy thermometer hanging in a pot & hang thermostatright next to it & see when it opens & don't open till 95 degrees celsius all the thermostats i bought total 4of them.as always thank you for your help.pepperone
Suggested Repair
Bleed trapped air by filling with the bleeder open, sealing the system, bringing it to temperature, cooling fully, then topping off. Use an 88C thermostat that actually opens at that temperature; units opening near 95C can run hot. A radiator hot only near the inlet indicates internal blockage and should be replaced. Reuse clean BMW coolant mixed with distilled water and change it about every four years. If bubbles or overheating continue, block-test and check for combustion gases before pressure-testing, because a leaking head gasket can force coolant into the cylinders. Belt tensioners are self-adjusting and need no manual adjustment.
Conversation Summary
A 1994 BMW 525i began running hot after the owner replaced the water pump, thermostat, hoses, belts, fan clutch, and expansion-tank cap. The radiator stayed mostly cool, the lower hose did not heat with a new thermostat installed, and air continued to appear at the bleeder. Experts advised bleeding trapped air, confirming the thermostat opening temperature, and checking for combustion leakage before pressure-testing. With the original 88C thermostat, the gauge settled near mid-scale, but the radiator was hot only beside the upper inlet, which an expert identified as a plugged radiator requiring replacement. After a new radiator, the gauge still reached about three-quarters, the lower hose stayed cold, and the hard upper hose suggested poor circulation; the owner suspected the thermostat and sent it for testing. No final confirmation of the cause appears in the thread.
