2003 BMW 525 Engine Throws a Rod - What to do?
2003 BMW 525
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
HYATTHOOD
My father's meticulously maintained 525i threw a rod according to BMW. To repair with BMW cost will be approx. $13,000 as the car is no longer under warranty.
The car runs, but makes a bad noise at idle. Are there alternatives to the BMW repair that could be considered?
What exactly should be replaced when an engine throws a rod? Maybe I could find some less expensive replacement parts if I knew what to look for.
Jul 14, 2008 at 9:16 AM
DOCHAGERTY
  • CAR REPAIR CONTRIBUTOR
  • 9,603 POSTS
I think what they mean is the connecting rod bearing spun. You could install a used motor for a lot less $$$. Call (619)444-2290 and talk to John @ Autobahn dismantling, tell him Paul Hagerty sent you.
Jul 14, 2008 at 10:02 AM
