1990 BMW 525i Late 4th Gear
SYDNEYE34
I have a 1990 Bmw 525i and i have a problem with the trans, it is late in selecting 4th gear, won't ever select until 70km/h.
I have given it a service.
Done a shogun reset.
And had a look for a trans speed sensor, which is what i thought it would be but this model of trans does not have one.
Any other suggestions anyone?
Month: January
Year: 1990
VIN: WBAHC22080BK97071
Jul 4, 2007 at 7:17 PM
DOCHAGERTY
  • 9,606 POSTS
repost with year and month of production
Jul 20, 2007 at 4:39 PM
DOCHAGERTY
  • 9,606 POSTS
sounds like the road speed sensor. the ZF 4HP22 has a road speed sensor in the tail shaft housing. or something inside the shift body. doing a service to a high mileage box can sometimes be fatal
Aug 14, 2007 at 6:40 PM
Suggested Repair
Check the ZF 4HP22 road speed sensor in the tailshaft housing, and inspect the valve body or shift body. A fluid service on a high-mileage transmission can sometimes cause shift problems.
Conversation Summary
The owner of a 1990 BMW 525i reports that 4th gear engages late and not until about 70 km/h, despite a transmission service and an adaptation reset. No transmission speed sensor was found. The expert suggests checking the ZF 4HP22 road speed sensor in the tailshaft housing or an internal shift-body issue, and notes that servicing a high-mileage transmission can sometimes cause problems.
