1990 BMW 525i Hesitation Off Idle
SYDNEYE34
I have a hesitation just off idle, if you pulll away nicely it is fine, but if you want to punch it the engine almost stalls then stutters then goes, can be dangerous, I have cleaned the idle control valve and tried adjusting the air flow meter no change. Am using premium petrol also.
any ideas?
Year:1990
Vin: WBAHC22080BK97071
Thanks
Jul 24, 2007 at 10:52 PM
DOCHAGERTY
  • 9,606 POSTS
check for proper valve adjustment, proper plug gap and
clean the throttle body. recheck the TPS and be sure that the switch clicks when opening and closing the throttle plate
Oct 31, 2007 at 6:49 AM
Suggested Repair
Check valve adjustment and spark plug gap, clean the throttle body, and recheck the TPS so the switch clicks when the throttle plate opens and closes.
Conversation Summary
Owner of a 1990 BMW 525i reports hesitation just off idle that nearly stalls, then stutters, under hard acceleration, while a gentle pull-away is fine. Cleaning the idle control valve and adjusting the airflow meter did not help. The expert suggests checking valve adjustment and plug gap, cleaning the throttle body, and verifying that the TPS clicks as the throttle opens and closes.
