1997 BMW 525 What could have happened
1997 BMW 525
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
MONEYBAGS
The car is a BMW 525I 1997 model with 145k on the clock. Performance was quite dull and a mechanic informed me that the cat converter was blocked. This was changed and the performance improved. I then needed an MOT test and the vehicle failed an emmision test. The mechanic told me that he thought the timing chain had jumped a few teeth and that the engine needed replacing. I decided at this point to take the car to a BMW specialist for a second opinion. This guy put the computer on it and said that the engine was fine but that some sensors needed replacing. He changed the camshaft position sensor and two ex probe sensors and charged me £700. When I picked up the car it ran superb. Response was there, power was there, everything great............for about fifty miles!!!!
I had to break heavy as a car pulled out in front of me. After that as I pulled away there was a massive screech from the engine as I got up to 15mph and it felt like the engine was braking and there was no power at all. I nursed the car about thirty yards to the nearest roadside pull in at which point the engine was vibrating and misfiring badly. I got a rescue vehicle to bring my car home.
Needless to say the BMW specialist is denying that this has got anything to do with his repair.
Can you give me any ideas as to what has happened here? Can a CPS replacement go so badly wrong?
Nov 8, 2008 at 11:27 PM
DOCHAGERTY
  • 9,606 POSTS
What was the outcome of the latest diagnostic from your mechanic. Something had to have happened to cause these issues.
Nov 9, 2008 at 3:33 AM
MONEYBAGS
I wont know until Monday evening. Car is being transported to garage tomorrow midday. I just wondered if anyone else had suffered a catastrophic failure so soon after CPS was changed.
Nov 9, 2008 at 4:01 AM
