2004 BMW 525 Oil Change
2004 BMW 525
HAYABUSA
Other Category problem
2004 BMW 525 V6 Two Wheel Drive Automatic 53000 miles
How do you change the oil in the BMW 525i?
Dec 9, 2007 at 11:15 PM
DOCHAGERTY
  • 9,606 POSTS
I have tried to answer these questions before and I have finally come to the conclusion that if you have to ask, then you should be seeking out a professional to perform this simple task. A 2004 BMW is not a difficult oil change. Remove the filter and drain the oil and then install a new filter and the correct amount of the right oil.
Dec 14, 2007 at 4:30 PM
