2000 BMW 328i A/C Low Pressure Switch
EXEC98
My 2000 BMW 328i a/c quit working. I have check freon and have correct pressure. I took out the a/c relay behind the glove box and replaced with new one. No changes. I jumped across the connections where the relay plugs in and the compressor kicks in and a/c starts working. I am trying to find the A/c low pressure switch to see if that is the problem. Where is the low pressure switch located or do you have any other suggestions?
Mar 19, 2007 at 7:03 AM
MERLIN2021
  • 17,250 POSTS
Low pressure switch is on the suction line...high pressure switch is on the high side line. Follow the lines till you see an electrical connection.
Apr 16, 2007 at 10:13 PM
Suggested Repair
Locate the low-pressure switch on the suction line and the high-pressure switch on the high-side line by following the refrigerant lines to an electrical connector. Because jumping the relay socket makes the compressor run, inspect the pressure switch and related control circuit rather than the compressor itself.
Conversation Summary
The owner of a 2000 BMW 328i says the A/C stopped working despite correct refrigerant pressure and a new A/C relay behind the glove box. Jumping the relay socket makes the compressor run and the A/C work. The expert says the low-pressure switch is on the suction line and the high-pressure switch is on the high-side line; follow the lines to the electrical connection.
