1987 BMW 3 Series High AC Pressure
DANNYB86
I have a 1987 325es with 250K miles on it. my question is the compressor comes on aux. fan works correctly and it has a full charge of 134a. i realize that this was a r12 system but the pressures seem to be way to high. it will cool down to about 60 deg.F but the pressure on the low side is around 50psi and on the high side it is around 300 to 350psi. what could cause the pressure to be so high and it not cool as good?
Aug 24, 2007 at 7:35 AM
DOCHAGERTY
  • 9,606 POSTS
there could be air in the system or the system could be overcharged. If the system required 1.86 lbs of R-12
and there was 1.86 lbs of R-134 installed then the system is overfull. The high and low pressures are dependent on the ambient temperature and humidity.
Try removing .25 lb. and repost your results along with ambient conditions
Aug 25, 2007 at 3:12 AM
Suggested Repair
Suspect air in the system or an overcharge, since installing the same weight of R-134a as the original R-12 capacity can overfill it. Remove about 0.25 lb of refrigerant, then recheck pressures and cooling while noting ambient temperature and humidity.
Conversation Summary
The owner of a 1987 BMW 325es reports that the AC compressor and auxiliary fan work and the system has a full R-134a charge, but it only cools to about 60 F. Low-side pressure is about 50 psi and high-side pressure is about 300-350 psi. The expert says air or an overcharge may be causing the high pressures, notes that matching the original R-12 weight with R-134a can overfill the system, and recommends removing 0.25 lb and reporting the results with ambient conditions.
