HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
BMW
328
Engine Cooling
Coolant Reservoir
1996 BMW 328
CAPITAL2000
MEMBER
1996 BMW 328
6 CYL
2WD
AUTOMATIC
200,000 MILES
Coolant tank crack, what caused it
Sunday, March 16th, 2008 AT 10:54 AM
DOCHAGERTY
MECHANIC
Age is a factor in the lifespan of the cooling system components BMW has decided to use. Heat and age and the thermal cycling and what is termed "electro-mechanical degradation" all are contributing factors.
SPONSORED LINKS
Sunday, March 16th, 2008 AT 11:23 AM
Please
login
or
register
to post a reply.
Related Coolant Reservoir Content
1996 Bmw 328 Ratiator Cooling Fan
Why Does The Ratiator Fan Keep Running When The Car Is Off? It Killed The Battery 8 Hours Later.
Asked by
golfking2005
1 ANSWER
1996
BMW 328
VIDEO
Coolant Reservoir Replacement
Instructional repair video
GUIDE
Transmission Fluid in Radiator Coolant Reservoir
All automatic transmission vehicles are equipped with an transmission fluid oil cooler, when transmission fluid is discovered inside the coolant reservoir or the radiator it...
1996 Bmw 328 Thermostat
Where At In The Hicle Is The Thermostat Located Because I Have A New Thermostat To Put In To Replace Old One.
Asked by
lildredamc
1 ANSWER
1996
BMW 328
1999 Bmw 328 Anti-freeze Leak
Small Valve Located On The Radiator Hose Is Leaking Anti-freeze, Right Next To Where To Pour The Coolant Into The Radiator. What Is It?
Asked by
madiuche
1999
BMW 328
Leaking Coolant On A Bmw
I Have A 2000 Bmw 328i With 123,000miles Coolant Has Been Leaking, I Have Replace The Radiator And The Head Gasket But Unfort. There Is...
Asked by
angelikasalcedo
1 ANSWER
BMW 328
1997 Bmw 328 Thermostat
Engine Mechanical Problem 1997 Bmw 328 6 Cyl Two Wheel Drive Automatic How Do I Replace The Thermostat? Pictures Would Help
Asked by
shave242
1 ANSWER
1997
BMW 328
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Coolant Drain and Refill Acura
Online car repair manuals
