1996 BMW 328 thermostat
1996 BMW 328
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
LILDREDAMC
where at in the hicle is the thermostat located because i have a new thermostat to put in to replace old one.
Jan 20, 2009 at 3:31 PM
DOCHAGERTY
  • CAR REPAIR CONTRIBUTOR
  • 9,606 POSTS
Here is an exploded view of the T-stat and water pump. The fan and the shroud need to be removed first, then the bolts can be accessed. The fan can be removed with a thin 36mm open end wrench and it is a left hand thread. The plastic buttons that hold the shroud often break and I usually replace them with plastic zip ties. I recommend replacement of the water pump if it's age is unknown and for preventive maintenance. _________________
https://images.2carpros.com/forum/automotive_pictures/87023_STFU_File0005_3.jpg
Jan 20, 2009 at 9:22 PM
