1999 BMW 328 Anti-freeze Leak
1999 BMW 328
70,000 MILES • 6 CYL • AWD • AUTOMATIC
MADIUCHE
Small valve located on the radiator hose is leaking anti-freeze, right next to where to pour the coolant into the radiator. What is it?
Jul 14, 2008 at 12:21 PM
DOCHAGERTY
  • 9,606 POSTS
That is the bleeder valve. It is available separately and take care when you tighten it, it is made of plastic and can be easily over tightened.
Jul 14, 2008 at 2:06 PM
MADIUCHE
Thank you so much!! Do you know what may caused it to leak anti-freeze from there? And also do I have to purchase that part from the dealer or can I get it from the auto part store?
Jul 14, 2008 at 11:42 PM
DOCHAGERTY
  • 9,606 POSTS
The plastic can and does often split and may require replacement of the expansion tank and these are usually not something they have on the shelf at Pep Boys. There are several on-line BMW suppliers, check them out.
Jul 15, 2008 at 1:17 AM
MADIUCHE
thanks again.. is this part hard to replace and will it harm my car if I drive it until I get the part?
Jul 15, 2008 at 1:21 AM
DOCHAGERTY
  • 9,606 POSTS
Not hard to fix at all, but I would not take the chance of overheating the car. Get this fixed ASAP.
Jul 15, 2008 at 2:06 PM
KARENCAREN
  • 72 POSTS
Replacing it its not hard. If you drove your car with that you might get more problem that is hard to fix.
Sep 2, 2008 at 1:54 PM
