1985 BMW 325 Odometer Gear
HAWKSRNO1
how do you replace the odometer gear?
How do you access the odometer?
mileage 202419
engine size 2.7 liters
Jun 25, 2007 at 2:16 PM
DOCHAGERTY
  • 9,606 POSTS
removal of the instrument cluster requires dropping the under dash in the drivers footwell to access two thumb screws that hold on the plastic panel just below the cluster, then remove the phillips screws that retain the plastic surround and then two screws holding the cluster in. A speedo repair shop can help you with this repair.repost if you need more help
Jul 23, 2007 at 10:56 PM
Suggested Repair
Drop the under-dash panel in the driver's footwell and remove the two thumb screws, then the Phillips screws on the plastic surround and the two cluster screws to remove the instrument cluster. Have a speedometer repair shop replace the odometer gear.
Conversation Summary
The owner of a 1985 BMW 325e with 202,419 miles asked how to access the odometer and replace the odometer gear. The expert explained that the instrument cluster is reached by dropping the under-dash panel, removing two thumb screws, the surround screws, and the cluster screws, and recommended a speedometer repair shop for the gear repair.
