2003 BMW 325i Headlight Flickers
BOBKNOWES2
2003 bmw 325i 30000 miles
Dec 29, 2006 at 6:48 AM
GARFIELD
  • 197 POSTS
It sounds like you have a loose connection at that headlight, check the electrical connector ensuring that it is making a good connection with lamp pins( be extemely careful with the bulb and DON'T TOUCH THE GLASS PART OF THE BULB OR IS WILL BLOW SHORTLY AFTER IT IS TURNED ON. If the connector is good then check the ground connection to make sure it is good and tightly connected without any corrosion. Lastly and very rare is that the bulb has a broken element that with the vibration of driving causes the element to make contact and will work till it vibrates open. Hope this helps
Gary
Dec 29, 2006 at 10:40 PM
Suggested Repair
Check the driver headlight connector for a solid connection to the lamp pins, without touching the bulb glass. Inspect the ground for tightness and corrosion. If both are good, the bulb filament may be broken and opening with vibration.
Conversation Summary
The owner of a 2003 BMW 325i reports the driver headlight turning on and off. The expert advises checking the lamp connector, confirming the ground is tight and free of corrosion, and considering a rare broken bulb element that contacts until vibration opens it.
