1987 BMW 325 Speedometer Not Working
KHALIDMIAH
THANKS FOR YOUR EXPERT ADVICE ON ALL THE TOPICS.
MY CONCERN IS THE SPEEDO METER ON THE INTRUMENT PANELS. EVRYTHING ON THE PANEL WORKS FINE BUT ONLY THE SPEEDO METER AND THE SMALL METER UNDER THE REV COUNTER METER THAT SHOWS MPG IS NOT WORKING. I HAVE REPLACED THE WHOLE PANEL CLUSTER BUT THE SAME PROBLEMS REMAIN. I WOULD BE GRATFEUL FOR YOUR HELP.[img:9fd99cf2e9]http://www.2carpros.com/forum/automotive_pictures/116407_SP_A0043_1.jpg[/img:9fd99cf2e9]
Nov 11, 2007 at 1:40 PM
DOCHAGERTY
  • 9,606 POSTS
The problem could be that it is not getting a speed signal from the switch in the differential. Put a DVOM on the switch and see if if shows a switching action when the rear wheels are turned.(note: this is a reed switch and is not able to generate voltage, so do not attempt to set the meter for voltage, set for resistance) You say you replaced the cluster, it is also possible it will need an S.I. board. as the tempo signal is generated through it. part # for the S.I. is 64-11-9-070-793. try this website
realoem.com. send me a PM if needed and I can assist you with this issue. Good luck!
Nov 12, 2007 at 6:28 AM
Suggested Repair
Check the differential reed switch with a DVOM set to resistance while turning the rear wheels; do not measure voltage. If the speed signal is present, the cluster may still need the SI board (part 64-11-9-070-793), which generates the tempo signal.
Conversation Summary
The owner of a 1987 BMW 325 cabriolet reports that the speedometer and the small MPG gauge under the tachometer do not work, while the rest of the instrument panel is fine. Replacing the cluster did not fix the problem. The expert suggests the cluster may not be receiving a speed signal from the reed switch in the differential and recommends a resistance check while the rear wheels are turned. The SI board may also be required because the tempo signal passes through it.
