2002 BMW 325 alternator
PARTIMER
  • 2002 BMW 325
  • V12
  • 10,000 MILES
Trying to remove the alternator. I have mounting bolts off. Alternator won't come loose. It will pivot back and forth about 2 or 3 inches bkut that is all.
Sunday, September 6th, 2009 AT 9:35 PM
DOCHAGERTY
  • 9,601 POSTS
There are two bolts that hold the alternator in, once removed, there is only the wiring attachments. What is holding it there is just the bolt going through the lower hole intercepts a trapped sleeve that has the internal threads in it, and the sleeve is holding it, put the lower bolt back in, (not all the way in, just a few turns in) thread it into the sleeve, get your hammer and give it a solid couple of taps, remove the bolt, and out it comes, am I being clear about this?
Monday, September 7th, 2009 AT 10:41 AM
