1996 BMW 325 Car is not starting
VARTAN
  • 1996 BMW 325
  • 6 CYL
  • MANUAL
  • 96,000 MILES
I have a new battery and car is not starting. Engine is cranking but do not start.I have checked all the fuses.
I like to know where should I check next. I addition I do have gas in the tank.
Thanks
Vartan
Saturday, December 26th, 2009 AT 3:27 PM
To determine if it's a spark or fuel problem. Do below:
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Saturday, December 26th, 2009 AT 4:33 PM
VARTAN
Do you think circuitry of the alternator can crete the problem?
Saturday, December 26th, 2009 AT 5:44 PM
Your problem here is its cranking over and will not start check and test what I've suggested earlier-The engine has to start before the alternator causes problems-check and test it and comeback with some results
Saturday, December 26th, 2009 AT 6:37 PM
