2002 BMW 325 car will not start
JESME87
  • 2002 BMW 325
  • 6 CYL
  • 73,000 MILES
Hi, the isuuse is that I left my car on the garage and the next day it will not start, I figure out that may be the fuel pump and I changed the fuel filter, there was no liking, then I went to check on the riley inside of the interior trunk and seems like everything was fine then I come over to check on the riley close to the engine and exchange riley and the car started but after a few seconds it shut off, I checked the battery and charge it of course but that is not it becuase all lights and the radio is working, I need any sugestion that you may have to fnd out what is wrong. Thanks
Saturday, January 3rd, 2009 AT 6:39 PM
DOCHAGERTY
  • 9,601 POSTS
It could be the fuel pump itself, check it for proper output. The car will start but wont stay running sounds like fuel pump, also replace the fuel pump relay.
Sunday, January 4th, 2009 AT 11:56 AM
JESME87
I went to ask for a new relay at auto zone and they told me to switch it off and input a new one to check if that was the problem and also they told me that the fuel relay is close to the engine in the seat driver side and it is a green one, when I change it the fuel pump started to work but it shut off in a few seconds afterwards and the issue ramain, I check the relay that they sold me and it had the same body and it looks the same but the numbers are not the same ones do you know if the green relay that I worked on is really the fuel one? Do you know if I affect any other parts by inputing a relay with diffrent series numbers? And since the fuel pump started to work do you think it is still necesary to replace it? Thanks a lot.
Sunday, January 4th, 2009 AT 5:10 PM
DOCHAGERTY
  • 9,601 POSTS
I am confused, did you replace the fuel pump relay? Are you sure it is the correct relay? Often the part numbers supercede and appearance can be confusing.
Monday, January 5th, 2009 AT 11:06 AM
JESME87
Yes I input a new one close to the engine like they told me to do at auto zone but I am not sure if that is the fuel relay it is a green on, when I changed the relay the fuel pump started to work but it shut off in a few seconds afterwards and the issue ramain, I check the relay that they sold me in auto zone it had the same body and it looks the same but the numbers are not the same ones
do you know if I affect any other parts by inputing a relay with diffrent series numbers? And since the fuel pump started to work do you think it is still necesary to replace it?
Do you know if this car has more then one fuel pump relay and if is green?
Thanks for your help
Monday, January 5th, 2009 AT 4:47 PM
DOCHAGERTY
  • 9,601 POSTS
The car has only one fuel pump. The fuel pump relay can be green, yes. I doubt any damage could occur if the fuel pump relay is replaced with an incorrect part, but anything can happen out there.
Tuesday, January 6th, 2009 AT 11:37 AM
