1992 BMW 325 power windows
JOJHNS8
  • 1992 BMW 325
  • 6 CYL
  • 155,000 MILES
My rear sedan windows wont work on either side? The rear window door button lights up on the rear right, but not the left. The console button doesn't seem to work either. But the front windows work. I changed the comfort relay. Is there a separate relay for the rear windows? Its not stuck either because the motor doesn't even come on. Whats wrong?
Tuesday, July 6th, 2010 AT 9:38 PM
DOCHAGERTY
  • 9,601 POSTS
The windows may well be stuck, power is there because the fronts work and the rears are powered through the same circuit. It may be switches or stuck motors, try removing the door panel and thump the motor with a mallet, most of the time that will do it.
Tuesday, July 6th, 2010 AT 11:29 PM
