1990 BMW 325 starting the car
RASTA420
  • 1990 BMW 325
  • 6 CYL
  • MANUAL
  • 215,000 MILES
I have a 1990 bmw 325i thats been sitting, I did a oil change and got a brand new battery and still wont start. I wants to start I turn the key over and it makes the noise as if it wants to start but it wont turn on. I was wondering mabey spark plugs?
Tuesday, February 24th, 2009 AT 4:17 PM
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Tuesday, February 24th, 2009 AT 5:10 PM
DOCHAGERTY
  • 9,601 POSTS
You may find a failed fuel pump is the issue here and after you follow the suggestions by Rasmataz, you may need to inspect and/or replace the pump and filter too.
Wednesday, February 25th, 2009 AT 8:48 AM
