My 1989 bmw will not start it has spark and I spray starting fluid in the air intake and still nothing
Monday, February 9th, 2009 AT 10:23 PM
DOCHAGERTY
MECHANIC
No spark and no injector signal could mean the DME has failed or the crankshaft sensor is not working. I know where it can be repaired for less $ than buying a new one.
SPONSORED LINKS
Tuesday, February 10th, 2009 AT 10:02 AM
GENE.MORGAN
MEMBER
It does have spark
Tuesday, February 10th, 2009 AT 2:14 PM
DOCHAGERTY
MECHANIC
I am sorry, after I re-read the first post I saw where you said there is spark. So if there is spark and you have tried spraying starting fluid in the intake, but it does not run, then is there spark at the spark plugs? I am thinking bad wires or cap and rotor. Has the fuel pressure been checked? Is the compression normal? Let me know the outcome of your tests.
