1985 BMW 325 oil pan replacement
VINCE_1015
Engine Mechanical problem
1985 BMW 325 6 cyl Two Wheel Drive Manual
i was wondering if anyone could give me a step by step for replacing the oil pan on my 1985 325e. thank you.
Apr 16, 2008 at 11:53 AM
DOCHAGERTY
  • 9,606 POSTS
I can assist you in the removal and replacement of the oil pan. First, drain the oil out of the engine. You will either need to hold the engine from above and then drop out the front sub frame, or lift the engine up off its mounts to gain access to the pan. Remove the oil pan bolts and you might have to rotate the crankshaft to clear the rear throws of the crankshaft. Clean the gasket sealing surface, install the pan and torque the bolts to 100 inch pounds.
Apr 17, 2008 at 4:22 AM
