OVER REVING
TREVORBMW
I OWN A BMW320I AUTO 1993 MODEL.WHILST DRIVING UPHILL ON DRIVE GEAR THE ENGINE SEEMS TO OVERREV AND THE CAR GETS STUCK IN GEAR.IT ONLY CHANGES BACK TO NORMAL WHEN I SWITCH OFF AND RESTART THE CAR.PLEASE HELP!
Sep 6, 2007 at 3:20 AM
  • 55,649 POSTS
is your car stick shift?
Sep 17, 2007 at 11:25 AM
TREVORBMW
NO.
Sep 19, 2007 at 6:07 AM
  • 55,649 POSTS
lets check the trans fluid level, and check the condition of the fluid. A transmission control seliond can cause this problem, also. You can try servicing the tranmission and see if that helps. If not you might be in the tank for a rebuilt trans.
Sep 19, 2007 at 8:14 AM
